RCU Forums - View Single Post - FuntanaX 50 - E-Conversion - Loop Problems and Firewall Angle Help
Old 03-16-2007 | 01:31 PM
sbritton
Default FuntanaX 50 - E-Conversion - Loop Problems and Firewall Angle Help
Hey everyone...I just finished a FuntanaX 50 electric conversion; running a E-Flight 60. It flys great except when doing loops...it wants to twist to one direction (can't recall which right now). This is particularly true the tighter the loop is. A big loose loop is usually pretty straight but I may be compensating with out realizing it.
So my question is what might be going on and how do I fix it?
I was considering a tip stall, but doesn't seem to apply because it is always the same direction and usually at a pretty good speed.
My final thought is it is related to the firewall angle/offset for a glow engine. So I tried to compensate for it with my mount, but the trial and error factor is a real pain in the butt. My mount is pretty simple, 1 1/2" PVC pipe as a spacer with 4 x 3" screws running through the firewall to surround the PVC and keep everything tight.
Can anyone tell me what the angle is on the firewall on this plane?
If I compensate for it to make the electric engine square to the thrust line will it solve the problem or create another?
Can I compensate for the issue with my radio (Spectrum7) to mix the alleron to the elevator?
Thanks for your help!!
