RE: Problems starting OS LA .65
Yup like he said...
Closing the throttle down, also reduces the aperture that permits the fuel to siphon back.
That means it runs back from the carb at a much slower rate giving you time to get the engine started.
You also don't really want to start a plane at higher throttle...
A high idle will do if you are unsure of the engine, and then at mid to low idle once you have the engine fully tuned up.
