RCU Forums - View Single Post - 4 stroke help needed
Old 03-16-2007 | 05:38 PM
blindguarden
Default RE: 4 stroke help needed
Low@slow ....it does have a new OS F plug in it thanks for the suggestion tho.
campgems,
I have done what you had suggested and now I have things running alot better. It now will run at full throttle and will run at idle with out quitting. I set the rpms at 9800 for the high end and set the low end about 2300 rpms.
it is still running a little sluggish when going threw the the transition from low to high. So does that mean that I need to adjust the low end a
little more?
thanks,
Blindguarden
