RE: Tower Pro receiver compatible with anyone?
My latest is the Berg 7P Horizontal pin RX. Just hooked it up and no glitches so far. As was just said above I was going to use a cheap Rx in my latest build and changed my mind after i tallied up around $400+ dollars in my plane not including airframe.
2-35mm motors
2-10" props
4-servos
2 Y-harnesses
3-extensions
3-ferrite rings
Carbon Landing Gear
2-Castle Creation 45 amp esc's those took a bite out of the wallet.
4-2000mah 3S lipo's made into 2-3S 4000mah packs.
1 Berg 7PH Rx.
Airframe $100.00
Misc. hardware.
Blah Blah Blah, you get were I am going with this.
I save my cheap Rec.'s for foamies. And am happy with them in this application.
