RE: blade cx pro
yes rjday............. the Dynam vortex inner and outer shaft are a direct replacement for the stock CX2. They are a little longer so you can't mix and match but definatly a solid fix if you are getting blade clack. The Vortex flybar also works well but you have to unscrew the lower half of the flybar link and replace it with the lower half off of your CX flybar. There are a myriad of posts on this subject...... ndoren, soloboss and neilt6 are the (in my opinion) experts on this subject.
My blades went right on the Vortex's hubs....no problems. Solid mod, good reports on it. Good luck!
__________________________________________________ _________________________________
Of all the things I ever lost..................................... I miss my mind the most!
