RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 03-16-2007 | 10:00 PM
  #4656
FERNDALE AIR FORCE's Avatar
FERNDALE AIR FORCE
Default RE: Air Hogs Aero Ace!
Brian, you have couple of options. DJstinger has/had some light kits. Megabyte-2 has the diodes and resistors to let you build your own light set. Both setups will require you to solder the lights into the circuit. It's not hard to do but if you are under 18 yo you should have your dad or someone help you.
