RCU Forums - View Single Post - axe cp thread
Old 03-16-2007 | 10:25 PM
  #499
chaseman81's Avatar
chaseman81
Default RE: axe cp thread
ORIGINAL: BoysToys
ORIGINAL: AirforceRcks
just a side note.
i broke the rear motor mount and its a b$%%& to get it back cause u gotta solder the motor back on and i aint no good with a soldering iron.
Thanks for the heads up. The soldering is not going to be a problem for me. I have made my own side by side NIMH packs for my trucks and soldered many a lead onto a motor. I am more intimidated my taking the head and main shaft apart to replace the main rotor gear. I will just take it very slow and lay everything out in an orderly fashion when I disassemble it.
The main gear is easy. you don't have to take much apart at all. undo the links from the balls all three servos let them lay. then under the FRAME (top) under the swashplate area is a wheel coller on the main shalt loosen that. ( now there will be play a little) undo the bolt hold the main gear on the shaft (tap out) NOW have someone hold the heli upside down firmly and tap the shaft out from the bottom (easy does it) use blowdryer for a moment and remove the gear.
Now putting it back togeter is easy too remember the d shape in the gear and bottom of shaft
line up holes in shaft and gear slide it on (tight) blowdryer a bit and boom she slides right on.
bolt throught hole shaft in bottom frame slide up the wheel coller tighten add links back to the balls everything should still be tracking well and your gear is installed.
about 15-20min job
Chaseman81
