Zeroing out trim settings
The aileron trim setting for my plane requires additional right trim to achieve straight and level flight. The additional trim is not extreme, maybe 24 increments on a Futaba 6EXA transmitter. There is one servo for the ailerons on this plane. Prior to the initial flight and trim adjustment the ailerons where level when the servo is in the neutral position, I have not looked at the aileron setup following the trim adjustment. Can I adjust the push rod for the right aileron to zero out the trim setting? Do I need to adjust both aileron push rods?
