RCU Forums - View Single Post - Twinman and Twin Sync. Lord Help Us all!
Old 03-17-2007 | 02:47 PM
Pilot44
My Feedback: (20)
Default RE: Twinman and Twin Sync. Lord Help Us all!
This is how I installed magnets in my setup. They are 1/8"dia. and about 1/4" long. These are RCV91CD thrust washer/bearing for my KMP B25, will not be using spinner so had to go this route. Works great. As the washer is open around the circumference of the bearing, it lends itself nicely to this installation. The sensor picks up the magnets up to 1/4" from the outer circumference of the bearing so there is room to work with. And there is no problem with the prospect of losing a magnet at high RPM due to centrifugul force should the bonding agent fail, which would not be good. No way this magnet gets out of there.
You just need to orient the magnets for the correct polarity as the magnetic field is generated from the sides of these magnets rather than the ends. Test with the sensors for correct alignment before gluing in.
Used JB weld to keep in place, balanced the thrust washers/bearing by removing a small amount of material via 1/8" bit next to the magnet.
Jim
ID:	643982   Click image for larger version
ID:	643983   Click image for larger version
