RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 03-17-2007 | 09:09 PM
  #1202
lookyj
Default RE: Wheeeeeeee.......... Blade CP!
rick,
the process has started..... I'm digitizing your tape into my computer system as I type... From what I've seen so far, pretty impressive for the first flights.
I too got the DX7 with DS821... my LHS said he DS821's are too big for the TREX 450, but would be great for the TREX size.... what are your plans for the TREX install?
meanwhile -
confusion hooking up the AR6100 to the BCPP 3in1...
figures the AR6100 uses labels as THRO, AILE, ELEV and the BCPP uses numbers ch1, ch2.... hummm
from what I can figure out so far, I have it hooked up like this
AR6100 - BCPP 3in1
AILE - ch1
ELEV - ch2
THRO - ch3
RUDD - ch4
AUX1 - ch5
GEAR - ch6
does this seem correct? any thoughts from the experts, test monkies, or expert test monkies?
Edit -
DO-H, not it..... just bind the AR6100 to DX7, then powered up... G90 won't arm, neither will 3in1.... back to the drawing board...
anyone out there working on a similar project?
