DO-H, not it..... just bind the AR6100 to DX7, then powered up... G90 won't arm, neither will 3in1.... back to the drawing board...
anyone out there working on a similar project?
What are your throttle travel settings set to? Set your low throttle travel to -10% and see if it arms. The receiver needs to receive a 1 millisecond or shorter pulse stream from the receiver before it will arm. If I am not mistaken, the Gyro needs the same signal.
Do you by any chance run a seperate esc for the main motor? If you do, do you have the signal wire from the throttle in on the 3 in 1 and the signal from the esc connected to the throttle out on the receiver?
