RE: ST2300 Testing and Experimenting
Pe' has a fix for the original carb and the engines are supposed to transition perfectly after doing it. Basically reverses the dog leg groove in the barrel with a dremel and the barrel spring allows the barrel to run in the right spot. No pump needed unless you need the tank on the cg.
