Wing Twist
Try bracing the root end flat against the table with some heavy weights, then place about a 1/2" block under the LE at the tip with a weight on the TE (again at the tip). Note: this is if the TE is twisted up, if it's down, block up the TE with a weight at the LE.
Let it sit overnight and see how it looks in the AM
