RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 03-18-2007 | 11:55 AM
  #1212
choppersrule
Default RE: Wheeeeeeee.......... Blade CP!
Rsking45,
On the CP with the throttle trim at mid point and you move the tail by hand, it is normal for the blade to spin, that is the gyro in the 4n1 doing it's thing to correct yaw. Move the tail the other way and the blade will stop spinning.
I'm not 100% sure that moving the crystal from the CPP TX to the CP TX would work. But I belive it will work, should only take a few minutes to do. If it doesn't work, you've lost nothing but some experiment time.
Crashcrash, what do you thing?
Dave / Choppersrule
ORIGINAL: rsking45
Hi all,
I have a questuon for you. On my cp when I have the throttle trim @ center and I move the tail by hand ,the tail blade will spin.Is the a sign of the tail motor going bad?
Also I bouhgt the g90 for my cpp and deceided to let it set for a while and learn on the cp.Can the g90 be put on the cp? Would it be a good thing If I change out the cyrstals from the tx that came with the cp and put them into the tx that came with the cpp to have use of the 5 channel?
