RCU Forums - View Single Post - Hand starting procedure...
Old 03-18-2007 | 03:12 PM
jester_s1
Moderator
Default RE: Hand starting procedure...
This is the first I've heard of spinning the prop backwards to start the engine. Are you flicking it just up to the compression then letting it flip back or are you flicking it through the compression stroke the same as when you start forwards?
