Roll it up on compression clockwise and then flip the nose cone counter clockwise . Be sure to keep clear of the prop.
ORIGINAL: jester_s1
This is the first I've heard of spinning the prop backwards to start the engine. Are you flicking it just up to the compression then letting it flip back or are you flicking it through the compression stroke the same as when you start forwards?
