RE: Which is the most competitive RTR?
An indoor track with lots of sharp turns and jumps, the ground is hard packed dirt.
Could you help me here:
1.) what ESC should I use with the Reedy 19T Quad Mag? I would like to go with the one of the cheap LRP AI ESCs with reverse, (around $50) but if they aren't enough the Novak GTS Pro Sport ESC is an option ($75). I would like to go cheaper where possible.
2.) A CHARGER! All I want is something that can quickly charge an SMC NIMH 4200mah stick pack. nothing more, nothing less. I don't need to charge LIPOs. Maybe the Super Brain 959 or something. Keep it around $50, could I get a full charge in 30 minutes?
3.) How much power do I need from a servo? is 80oz at .15 sec enough?
4.) What else do I need? grease? oil? tools? anything?
Thanks.
