RCU Forums - View Single Post - Two things
Thread: Two things
Old 03-18-2007 | 08:58 PM
ehroof
Default RE: Two things
just have to turn the idle screw clockwise to stop it from closing when you hit the brake, its the one with the spring on it under the air filter this will stop it from shutting off. you may have to turn the throttle trim down on the radio to lower the idle once you get the idle screw adjusted
