Well....Drilled all the holes to mount the retracts, Epoxied the nacelles to the wing, finished shaping the fins and rudders. I still want to be sure of a good bond between the nacelles and wing, so after the first gluing has completely cured, I'll get around the edges inside with some fiberglass and resin to reinforce the joining. I also have all the control surfaces (except the rudder and fin) glassed and ready for the first coat of primer. I'm still not sure how or where I'm to install the throttle servo. I'm going to use mini or micro servos, so I know I'll be able to get in the nacell through the retract openings.... I was also able to fill and sand the wing crutch to the contour of the wing, mount my elevator and rudder servo rails. Not a bad weekend....
