RCU Forums - View Single Post - Got it running again but....
Old 03-19-2007 | 11:13 AM
MiniCwik's Avatar
MiniCwik
Default RE: Got it running again but....
So you put the fuel tubing on the other side of the brake lever, right?
Also, look down into your carb when you hit the brake, does it close the opening all the way? If so ... you need to adjust your idle screw to stop it from closing the 1mm opening that you should have at idle.
