RCU Forums - View Single Post - Falcon 40 (Exceed heli) Forum
Old 03-19-2007 | 03:01 PM
  #762
robotronski
Default RE: Falcon 40 (Exceed heli) Forum
ORIGINAL: joeyhatch11
Here again is the same question that has yet to be answered. After you guys got your falcon 40's what adjustments had to be made as far as trimming? Is it more done with the controller or the heli? And what exactly has to be done? Thanks
Look real early in this thread and I've got some setup tips.
At the heli, mostly worry about keeping the flybar paddles at zero degrees (in same horiz. plane as the ground/landing skids/tail boom etc...) Both must be at zero degrees, everything els you'll do at the transmitter. Loosen the philips screw to adjust them. These tend to get whacked out in shipping I assume...
I had to add a few clicks of Down and a few clicks of Rudder trim as well.
Flies fine after that.
Let me know if you have a more specifuc problem... Happy to help!!!
Robo
