RCU Forums - View Single Post - THROTTLE PROBLEMS ARGHHHHH!!!!!!!!
Old 03-19-2007 | 04:46 PM
Da Smak
Banned
Default RE: THROTTLE PROBLEMS ARGHHHHH!!!!!!!!
Just use the correct servo arm that is included with your kit. You do know that there are different tooth counts on the servos and horns, mate the wrong ones and you get your problem. Also ditch the Hitec servos, they themselves cause this as the ynever center to the same place twice, so that makes it hard to set up your ride too.
