RCU Forums - View Single Post - ultra thrust mufflers
Thread
03-19-2007, 07:13 PM
8
Ed_Moorman
My Feedback: (
1
1 Post
RE: ultra thrust mufflers
You are correct about the Ultra Thrust. Here is a photo of one I cut apart after I broke the mounting ear in a crash.
The Tower muffler is a large, expansion chamber that gives a good bit of tuning. I have gained 800-1000 rpm on .46-.52 siezed engines. You can gain 1500 rpm or more with an Ultra Thrust provided you use the correct size prop. The Ultra Thrust, and the Jett, which is similar, are cut to length for a fairly high rpm range. You need to use a prop that lets your engine run at that rpm. Generally, they need to turn a minimum of 13,500-14,000. You can definitely hear when they stage on the pipe.
Reply
Like
Ed_Moorman
View Public Profile
Send a private message to Ed_Moorman
Find More Posts by Ed_Moorman
View iTrader Profile
