Sounds like you're doing this a little back *****wards. This should have been done before the covering started, and the thin covering strips should have been applied first, and then the tail feather covering. I wouldn't worry too much about it at this point. Use filler if you think it will hold, otherwise, forget it, you'll never see it at 500 ft.
