RE: Air Hogs Aero Ace!
3D, Take the guts out of your jet and put them in your mono for increased speed, the jet motors are longer and have more power. Then take your AA Rx and do the mosfet upgrade to it, then you can install some Super Slick motors and put it in your jet, you will not believe how fast your jet is now.
FERN, can you charge the lipo with your Triton Jr. through the stock charging port? I know the Rx has a cut off built into it but does the Rx have anything to do with charging or is charging all in the Tx. If it's in the Tx couldn't you take the charging plug from a Tx and hook it up to your Triton then just plug it into the stock charging port instead of installing your own charging port.
