RE: Got it running again but....
the brake needs to be adjusted, you need to turn the knob at the end of the throttle linkage to tighten the grip on the brakes. You said you checked the fuel lines, did you blow in the one that connects to the exhaust and see if it flows freely from the fuel supply hose, you have to disconnect it from the carb, there should be little resistance.
