RE: Got it running again but....
no, once it starts to run that should be enough to get it going. maybe the needle is clogged, unscrew the high needle and see if something is clogged. I know i said it before but make sure your at 2 1/2 on the high needle and flush with the low needle. Do you have a temp gun? Did you ever have it running good before? Does is have decent compression?
