RE: Radios
rageman ,
Range is sort of 'fixed' in that there is very little difference in power output between the various different brands/models of radios. Probably not enough difference to really make any difference. So, I would think that finding a system that 'felt' good in your hands, has the number of channels you want/need, and doesn't break the bank would be more like it. The choice between the 'mode' of use, AM, FM, PCM, or 'pickle in a pear tree', is sort of up to you. More expensive doesn't necessarily mean 'better', nor does it mean 'worse'. It's your wallet, have at it!
- 'Doc
(I'll make you this absolutely fabulous deal on an older tube type system that you have to haul around in a trailer. The optional power plant to run it costs extra...)
