RE: Painting wings and stabs on pattern plane
Be careful about glassing foam cored wings with polyester. The Styrene monomer in the resin may melt the foam. (depending on what foam it is).
Provided you used a very light cloth and the minimum possible resin (Ideally by vacuum bagging) the weight gain is most likely acceptable. Why would you bother though?
