RE: How to fix high Angle of Attack
I stand corrected, after looking at the pictures posted by Tall Paul, the AoA on Groovy is not 20 degrees. I would say its more like 10 degrees in normal flight and around 15 degrees during landing. The plane flew very well overall and I had no problems with control on landings whatsoever.
I'm wondering if engine thrust line has anything to do with AoA. The engine is side mounted and I may have inadvertently added some up or down thrust while mounting the engine. If the AoA seems higher than normal, is this a sign of upthrust or down thrust?
Thanks.
