RE: Testing E-plane on the ground--good/bad?
stash,
ummm, yes you can taxi around a bit, but check the temps not only on the motor but also the esc and pack. The esc will get hot just sitting still and plugged into the pack. Unless the electrical components are out in the airflow, taxing around could easily over heat something if done for an extended time.
