RCU Forums - View Single Post - BlackJack conversion 2.0
Old 03-21-2007 | 04:58 PM
SouthJerseyFe's Avatar
SouthJerseyFe
Default BlackJack conversion 2.0
Well this was a 3 month project that got 99% finished and then ripped back apart due to a power system change. The electrics start with a 12XL, Hextronic 20 volt 120 amp ESC (custom water cooled). A 30 cell Super Bec 5 volt out put provides the power(it's hidden under the carbon fiber radio tray). A Jr Z590 high torque steering servo cranks the rudder. A Jr DX3 Spektrum system provides the inputs. Two 3 racing fans are installed on the motor and esc for a little extra insurance. Note the dual independent water cooling systems feed by through hull gundert pickups and led out by bulkhead fittings with an OSE water jacket. The motors bolted to an OSE DR mount. The tunnel was double laminated with 2mm lexan and 1/32 birch layered in 2ton hold devcon. The stuffing tube was extended 2 inches. I laminated the transom with 1/32 birch to seal up all the holes from the factory setup. As you can see the outdrive system was replaced with an octura strudder sporting a skeg strut. I have chosen a 45mm carbon fiber prop to start testing with. I will be running 3 sets of custom packs build for me by www.Battlepack.com. 2 sets of 7 cell IB3600s and a set of 8 cell 3600s. I chose these cells for there reliability and great voltage. Not to mention they are the best built packs you can get. This boat was built almost entirely from www.offshoreelectrics.com. Right down to the hull. The service from both sites is excellent and shipping is always lightening fast. A pleasure to work with all the way.
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
