RE: covering woes!!
acarter,
i have a solution to your problem that i have used and continue to use. it has been very helpful. Get the Top Flite Monokote "Secrets of Great Covering with Top Flite Monokote" DVD or VHS. Even if you use another covering beside Monokote it will help show you the tricks needed to cover your plane correctly. I recomend it to all first timers on covering a plane.
