RE: Help needed getting a vintage Enya 35 r/c to run well
One point about air bleed carbs that have been sitting around too long. Some castor may have solidified in the air passage where the air bleed needle is located. If opening the air bleed screw dosen't make any difference take a pin or piece of piano wire and push it through the air hole (phew) to clean out the old oil.
Peter
