ORIGINAL: Tail Spin
Hi All
Thinking of purchacing a new plane my trainer will do the basics but I would like to move on to a more acrobatic plane.
I quite fancy the new CM Pro 330L with a nice four stroke on board but not sure if it is a bridge too far. Is there any others that make
a good step in ARTF ?
Tail Spin
Whether its a bridge too far depends on you. If you are in total control of the trainer then it should not be. But be aware that the Extra will not land as slow as your trainer, needs a bit more speed. If you want to be safe then settle for any trusted low wing trainer, if you are confident and your trainer/tutor says you are good then maybe go for the Extra. The CMPro Extra is a beautiful plane but if the covering is like the Giles then it tends to rip, not come off only but rip.
