RE: Extreme Flight Edge 540T-E
I flew mine again after work yesterday. Now with the CG in the correct position, it flys very well. I ended up adding a spinner, and with the battery right behind the motor, the plane balances in the middle of the CG range. Hovers easily and is very stable where it is now.
Good luck with your maiden ScottChrist, I believe you will love it.
