RCU Forums - View Single Post - Quick Question
Old 03-22-2007 | 12:24 PM
mattnin's Avatar
mattnin
Default RE: Quick Question
ORIGINAL: Gtremmel
I just want to know if setting your controller at %125, for things like steering, braking, and throttle, is bad. Will it damage my car if I have everything set at %125? If not, then why wouldn't you always have it at %125?
It is not bad to set it at %125. It is a matter of how you tune your settings though. For instance, most ESC require you to set the speed control at your highest EPA setting for the throttle, and calibrate from there. If you need more range of motion with your servo, you might be required to go past %125. If you are hearing buzzing coming from your servo, then it is set to far and you will have to set the trim, sub-trim, and EPA accordingly.
