RE: Need resources
Veggi-Boost combustion enhancer is available in 500ml cans for people to create their own specialty fuel. It is essential to anybody using vegetable oil as a diesel fuel and will improve performance and help protect both the engine and the environment. Veggi-boost is a cetane improver and is added at about 0.1 % volume. Just a tiny amount has a large effect. It contains nearly 100% 2-ethyl hexyl nitrate which aids detonation inside the engine combustion chamber, enabling vegetable oil to be used more readily in a diesel engine. Also great if you're thinning veg oil down with petrol - it will restore the cetane value of the blend[img]C:\Documents and Settings\ugo\Documenti\Immagini\veggiboostsmall.jp g[/img]
