RCU Forums - View Single Post - Nitro Models Electric E-3D ARF
Old 03-22-2007 | 02:42 PM
opjose's Avatar
opjose
Default RE: Nitro Models Electric E-3D ARF
Which plane is this?
I don't see it up on the web page.
Could you post a link?
(Edit: Never mind... I forgot to look at the Electrics )
I have a bunch of Nitroplanes airplanes and every one has had the C.G. measurement either against the fuselage or in the case of biplanes, and a few monoplanes, measured from the mid point of the wing, leading edge front.
I would not go by the wing tips.
Better to be nose heavy and remove weight as needed.
Remember that shifting the engine a 1/4" forward can obviate the need for much of the extra weight...
Note: Similiar models in G3 have the C.G. fairly close to the fuselage measurement you are stating.
You could always check with one of the on-line C.G. calculators.
