RCU Forums - View Single Post - engine position at break in??
Old 02-17-2002 | 01:17 PM
Rodney
Default engine position at break in??
Mounting position should not matter. The only problem might be (if you mount it inverted) is getting raw fuel in the combustion chamber and getting a fluid lock which could damage the connecting rod if you are using an electric starter. A side or upright mount should run and start the same.
