RE: Air Hogs Aero Ace!
Nice vid tony, the problem I've had with the jet models is poor turning ability at speed. It appears you've solved that.
DJ, the wrapping wire is 0.01 inches in diameter with the insulation. I don't know what the amp rating is. When charging the triton jr puts 0.1A through it. Three weeks worth of charges with no problems, knock on EPP. I hope that helps. Tim
