RCU Forums - View Single Post - PICS OF MY NEW PLANE....
Old 03-22-2007 | 10:03 PM
-EXTRA-'s Avatar
-EXTRA-
Default RE: PICS OF MY NEW PLANE....
ORIGINAL: agexpert
Well,
That would be even better, although the .82 might be better PW compromise. I'm pretty sure it would pull out of a hover with reasonable authority. I guess you would need to check the specs...and the price.
The goal here is STOOPID power without adding weight to the plane at all, and keeping it as light as possible...and with proper prop-clearance etc...etc. A .91 would be a maximum...and most .91's would likely be too heavy.
That much power would require some experience with throttle control. I would bet that you are able to fly it, but in, 'recovery-mode', it's easy for a plane like this one to get away from you.
Take it slow.
Yea i read with the .82 it would hover at 3/4 throttle and with the .91 its straight up as far as you can see,im thinking about a magnum .91,and yes def im takin it slow..
