RCU Forums - View Single Post - FS One by Hangar 9
Old 03-23-2007 | 01:32 AM
  #742
Robotech
My Feedback: (9)
Default RE: FS One by Hangar 9
That is in fact the FAQ I used to set up the 9CAP. As I indicated earlier the sliders move all the way right and left for throttle when you move the stick at the first transmitter display and in the editor itself. The servo graphic at the extreme right hand side of the editor moves the full travel also. The stick has an effect on the throttle when you are " at the field ' but it is stopped at the lowest stick position and only barely spinning at the uppermost stick position. When I have the airplane inset pulled up in the transmitter editor the sticks do not cause the prop to move at all. Weird.
The realism of the Edge is very, very good but would be easier to evaluate if I could use my 9CAP. Maybe I will delete it again ( the 9CAP ) and start from scratch but I've done so several times and I feel as though I must be missing something simple somewhere. Do I need to have the frequecy module plugged in. I removed it so that I wouldn't have to extend the antenna and to conserve battery power. All the other control surfaces move correctly to their extremes though.
BTW. Your effort, professionalism, ability and dedication to solving problems for end users and your desire to improve the product is very much appreciated by 99.9 % of the posters here. I guess those .1% of posters make it necessary for you to have a thick hide. I might have launched a few missles at them by now. [:@]
Thanks again.
Robert
