RCU Forums - View Single Post - CH ignition versus Chinese version.
Old 03-23-2007 | 03:35 AM
  #56
gpar
Default RE: CH ignition versus Chinese version.
It´s no problem measuring arcs just marking on a piece of paper on the hub.
As I said before applying this method to my stock spe 26 with a different chinese ignition (from another company) I found out the static angle is just 27,5 degrees, instead of the 40 in the case of the rcexl ignition.
I wonder if such a big difference means a big tolerance for the static angle.
I think better ignition gives you more top rpm and more power, but then the setup angle should be found by moving the sensor by hand at open throttle.
