RCU Forums - View Single Post - FS One by Hangar 9
Old 03-23-2007 | 12:50 PM
  #752
MSelig's Avatar
MSelig
Default RE: FS One by Hangar 9
ORIGINAL: Robotech
If it might help these are screen shots of the xmitter editor. I was incorrect in my last post when I said the throttle has no effect on the plane in the " Show AC " inset. It behaves in the same was that it does " At the Field "
I deleted the setup, recreated it and recalibrated. Same result.
Pic 1, 2 and 3 are with the stick centered. Pic 4 and 5 are throttle stick up and down.
Thanks again.
Ok, your description has narrowed down the possiblilities. I think what's happening is that your Tx switch/dial that's connected to Axis 1 is not centered. We use Axis 1 for resetting the airplane. So when you run the sim, the sim is reading a constant reset. When I do this on my system the prop turns very slowly like you describe.
The solution is to center the dial or switch that's connected to Axis 1. Axis 1 should be centered like shown in the image below.
Does that fix it?
Michael
