RCU Forums - View Single Post - question about fuel?
Old 03-23-2007 | 08:56 PM
Pit-Viper 1's Avatar
Pit-Viper 1
My Feedback: (12)
Default question about fuel?
I was just wondering if the Curtis Youngblood blend from Wildcat would be ok to use for break in? I know that your not supposed to use castor for fear of messing with the regulator, they use the Benol brand castor. This is what it says about it;
BENOL CHARACTERISTICS: BeNol has a 25% greater film strength, higher load carrying capacity, and reduced varnishing properties than the lower grade AA castors.
Smoke Rating: 4-5 1=Fog 10=No Smoke
Clean Burn: 3-5 1=Heavy Deposits 10=No Carbon
Film Strength: 10 1=Failure 10=Virtually No Wear
Viscosity @ 100 F 950 - 1000 SUS 50W @ 40 C: 220cSt
Pour Point: 0 F
Flash Point: 520 F
Rust Prevention: Contains rust inhibitors
Certification: A.P.I. S.A. Intended for Racing Engines
Biodegradability: 100%
I have about 1/4 gallon of it that I had left and was just wondering if I should just use it for starting fires or if it is ok to use?
Thanks Shane
