RCU Forums - View Single Post - SIG Fourstar 40 (4*) Build Thread
Old 03-24-2007 | 11:49 AM
rwright142's Avatar
rwright142
Default RE: SIG Fourstar 40 (4*) Build Thread
After inventorying the parts I labeled the W-1 ribs because they came loose. I then started on the right wing. I pinned the spars to the plan and dry fitted the ribs. Next I glued the ribs and added the TE sheet to the top of the ribs. I used the dihedral jig for the inboard W-1 rib.
ID:	648747   Click image for larger version
ID:	648748   Click image for larger version
ID:	648749   Click image for larger version
