i only had some tree damage from the wind and a few parts off the house behind mine coming over the fence but no damage to my house at all, thanks.
on the balance with no fuel in it if i set it on a table it'll sit on that fat hump and balance like it's sitting on an egg so according to cobras 'by the plans' i may be a bit tail heavy but it files great even at idle it'll fly as smooth and slow as a high wing trainer. on the comment about the rolls that's about all i do, split S and roll it the length of the field about 10' off the deck, it's the only plane I've got that doesn't loose any altitude at all doing rolls, be they slow ones or so fast it's a blurry blob in the air, you just have to make that pause and make sure of the orientation before you push or pull elevator
kc
