RCU Forums - View Single Post - 2 Stroke HELP!!!!!!
Old 03-24-2007 | 07:43 PM
happypappy
My Feedback: (10)
Default RE: 2 Stroke HELP!!!!!!
Also, what you describe is an indication of a rich setting...having to have the plug artificially lit by the glow starter. Try going back to basics. Close off your high and low speed needle and hook up a fuel line to the carb. Open the LS needle until you can just blow through the line then open another 1/2 turn or so. Open the HS needle to around 2 1/2 turns for a base line and try that.
