RE: Wheeeeeeee.......... Blade CP!
Disregard, Crash already pointed this out...
Lookyj,
You still have your elev and pitch servos reversed. The back servo that is on the other side of the boom from your tail rotor blade should be plugged into the Aileron Channel on the receiver. The servo on the same side as the tail rotor blade is the pitch. Swapping these will fix your problems.
